LarryFine
- Henrico County, VA
- Electrical Contractor
There are switch boxes that will fit in a wall with a pocket door.
That always bothered me. Every old home I get called to wants a ceiling fan/light in a room where there is no existing luminaire, but rather a switch controlled receptacle. I mean I get that lighting can be a personal thing, but it would be nice to have a requirement for a ceiling mounted switch outlet provision.A wall mounted switch on the wall? And no luminaire required (yet).
One of the first renovations I made in my house was to move the bathroom light switch from outside to inside. Then I added a vent fan.If that were true, the requirement would appear in Chapter 296-46B of the Washington Administrative Code (WAC). It does not. It may be required in some states, but WA is not among them. I have stayed at places where that is the standard configuration, including some hotels in some foreign countries. I don't like it. If you have to use the bathroom in the middle of the night, turning the bathroom light on with the door open will disturb your sleeping partner.
210.70(A)(1) Habitable Rooms.
At least one lighting outlet controlled by a listed wall-mounted control device shall be installed in every habitable room, kitchen, and bathroom. The wall-mounted control device shall be located near an entrance to the room on a wall.
By this, would say a wall mounted remote holder faceplate meets the wall-mounted control device? Sure the remote can be removed, but it is the intent of the manufacture and installer that the remote shall be returned to the wall.I assume wall-mounted control device means it can be wired switch or a remote control.
Also, if as a kid, you have a brother like I did, you don't want someone else to control the light (not that I ever got even!). . . I have stayed at places where that is the standard configuration, including some hotels in some foreign countries. I don't like it. If you have to use the bathroom in the middle of the night, turning the bathroom light on with the door open will disturb your sleeping partner.
Not really sure I would accept a control in a wall mounted holder, as the control is not wall mounted. The language require a wall mounted control device, not a wall mounted holder for a control device.By this, would say a wall mounted remote holder faceplate meets the wall-mounted control device? Sure the remote can be removed, but it is the intent of the manufacture and installer that the remote shall be returned to the wall.
HA. They have overstepped their own rule here many times already.never thought I'd live to see it (of course that could be said by many things these days)
I submitted similar changes over the years with "the NEC is not a design manual" as the CMP reply.
Now, if they will only standardize wire color coding within buildings ( 120/208 black/red/ blue/white and 277/480 brown/orange/yellow/gray). It’s idiotic that this is not already a standardized NEC code.It is probably not an issue but many threads in the past stated that there was no where in the nec that required a switch to be in the room or near the room that it controlled. Well, that has finally changed
I wonder if they will soon require an outdoor light to be switched near the door where the light is illuminating.
That is design decision and hope it stays that way. All that is currently required is identification if there is more than one voltage system present on the premises and that works fine. Identification does not have to be by color either.Now, if they will only standardize wire color coding within buildings ( 120/208 black/red/ blue/white and 277/480 brown/orange/yellow/gray). It’s idiotic that this is not already a standardized NEC code.
I believe the state of Washington has a rule that bathroom switches must be installed outside the bathroom.
Are you saying that you fish in an additional single conductor?Again, I can rewire it so the switch leg is a feed, but I'd like to just add the red wire to the feed and fish up a wire from the switch.
Are you saying that you fish in an additional single conductor?![]()
Whew! Scared me for a moment.
For existing work, sometimes you have to open the receptacle, sometimes you don't, to add a switched ceiling light.
It also depends on whether you're adding a switch or two, or just keeping the single switch and rewiring the receptacle.
My preference is to split-wire every receptacle in the room using 3-wire, as well as running 3-wire to the ceiling outlets.
