Situation:
Residential
Unfinished poured or block basement walls
Adding boxes for receptacles and switches
What method do you use to secure the EMT? Do you use a straight connector at the box and a one-hole strap and not worry about maintaining consistent offset? Do you use an offset connector at the box and a one-hole strap? Do you use a straight connector and a mini? Do you use a straight connector and some other offset strap like the Crouse-Hinds Bendsaver strap? Some other cheap and fast option I did not mention?
Residential
