Jerseydaze
I was told awhile ago that New septic systems require an explosion fitting has anyone heard of this and what fitting would you use?
Jerseydaze said:I was told a while ago that New septic systems require an explosion fitting has anyone heard of this and what fitting would you use?
electricalperson said:most septics ive done in residental are only 2 float switches (on/off for pump and emergency alarm) and a pump motor and ive never used explosion proof fittings just 3/4"+ pvc and a few boxes
I guess most are that way, but some are more elaborate. I guess one typical extreme for resi would be:electricalperson said:most septics ive done in residental are only 2 float switches (on/off for pump and emergency alarm) and a pump motor and ive never used explosion proof fittings just 3/4"+ pvc and a few boxes
Jerseydaze said:I was told awhile ago that New septic systems require an explosion fitting has anyone heard of this and what fitting would you use?
Who was enforcing that one? Sounds like another xxx xxxxx requirement... :roll:ishium 80439 said:In CT it was a requirement for us (Fairfield County).
I wasn't aware that an inspector could summarily classify an area, anyhow.stickboy1375 said:Who was enforcing that one? Sounds like another xxx xxxxx requirement... :roll:
mdshunk said:I wasn't aware that an inspector could summarily classify an area, anyhow.
some of the motors are hard wired, and some are plug in. usually the plug in models have plug in floats that the motor plugs intostickboy1375 said:Do you install the receptacle inside the tank?
i wired a lot of tanks like that. the simpler version is just a preference for people. commercial has systems like thismdshunk said:I guess most are that way, but some are more elaborate. I guess one typical extreme for resi would be:
- low operating float
- high operating float
- high-high alarm float
- pump motor conductors
- pump winding temperature thermostat
- red warning light beacon for tank.
Some of the controllers can be as simple as a relay and an alarm horn, and some are rather ellaborate. The fancier one's will alarm out of the pump has run X number of seconds or minutes without satisfying the low operating float yet.
electricalperson said:some of the motors are hard wired, and some are plug in. usually the plug in models have plug in floats that the motor plugs into
Bell box with Woodhead cover inside of the tank, mounted near the top.stickboy1375 said:I realize that, but do you install a receptacle inside the holding tank? I'm just curios as how other electricians wire pumps inside of septic tanks...
not quite sure what woodhead is slang for, but i install a GFCI, bell box and a bubble covermdshunk said:Bell box with Woodhead cover inside of the tank, mounted near the top.
