- Chapel Hill, NC
- Retired Electrical Contractor
Okay-- let's see if we can put this issue to rest. I have made an absolutely turn around from my first post where I said I did not see anything illegal. I have talked to the Southwire technicians who apparently has dealt with this issue for years.
He says there is nothing readable that is absolutely black or white on this issue but he says SE cable because of the bare conductor is not designed for underground in a conduit. If water gets into the conduit then the minerals in the soil will also be present in the water. Those minerals will eat away the bare aluminum conductors if the jacket is breached.
The jacket, as we all know, is not design to resist tear the way a UF cable will resist tear. If it does the wire will almost certainly fail.
If we as members of the forum accept the fact that aluminum in contact with soil conditions is dangerous then we need to not condone this installation. We can argue the code wording forever but why take the chance-- don't do it. I believe our standards should be higher than this and to assume some responsibility for a potentially dangerous situation when the code does not address an issue well. Play it Safe Silly (P.I.S.S. not K.I.S.S.)
