volt102
 - New Hampshire
i found out that in 2002 the nec tried to put in a distance on this and it was turned down. so there is no set distance.
Is it that there was no set distance because it can be over 100' away, or is there no set distance so that it can only be 0' away?
I read 230 and see that a disconnect is required for the service. I read 225 and see that outside feeders require a disconnect at the building. I see 225 and 230 applying generally. This is not a case of chapter 5 modifying chapter 2....
I read Part II of the article that Jeff wrote first. I contacted him to get Part I. That article was then brought up to the IAEI meeting for a little debate. Unfortantely Jeff was not in attendance that night.
Just my 2 cents....
