Service Lateral or undergound feeder
Karl Warner
New member
For an underground residential lateral.
Situation- service drop to Pole..original 100 amp service with
pole monted Breaker Panel.
Owner installed a breaker panel inside the house. He fed the new 100 amp panel from a 100 amp breaker on the pole. However he ran underground service conductor (no ground). I know you can tap the service condutors
per 230.3. I cannot find anything in the code that prevents this (Can a service be fed from a breaker in outdoor breaker panel which is system bonded going out as service lateral and still be called a service,)
This could be considered a feeder since the conductors originate from
an overcurrent device... in a service bonded panel at the pole.
problem the 3wire service underground already run
I believe he could sub feed throuigh lugs at the bottom of panel ( will be installing new outdoor panel with subfeed lugs if necessary)
This is still legal if the 2008 NEC has not been adopted yet. If it has, then you either need to tap the service conductors (make it a service per 230.40 exception 3) or run a separate grounding wire with the other set of conductors. Sub feed lugs won't work if the panel is a main breaker style (because the wire to the house is still a feeder). Not even sure if sub feed lugs are rated for Service duty or not.
pole mounted Breaker Panel.
With the breaker at the pole this is without a doubt a feeder.
Wes Smith said:
I believe that since the service point is at the pole mounted panel, you need a separate ground from that point on.
Under the 2008 that is true, under previous codes you could use the grounded conductor as the grounding conductor.
250.32(B)(2) in the 2005.
