services
chidesd
New member
I have a new 200amp panel installed and a 2"
nipple out the back for the meter box. Is it ok
per code to cut a hole in the back of the
meter box or do I have to use the knockout that is
on the bottom of the meter box?
[ June 17, 2003, 09:30 AM: Message edited by: chidesd ]
Re: services
Every Meter Enclosure I have seen has had a knockout in the back of it. I'd suggest that you have someone more familiar with this look at what you are trying to do.
Bill
Re: services
chidesd, you might check with the serving electric utility. In some of our meter equipment, we do not permit exits out the back. :)
Re: services
We still supply meter fittings and because our customers want our cash register as small as possible, we accommodate them with small meter fittings. Our equipment doesn't have the wire bending room that is required to make the bends in some of out fittings.
This is especially true when we use a 400 ampere, three phase meter fitting with bar type CT's. Since we restrict how some of the wiring is done, I would assume (d - - -, I don't like that word ;) ) other electric utilities have their own rules since that is where they will plug in their cash register.
