Irving LaRue
- Warrenton, Virginia
- Electrician Apprentice
My master electrician who I shadow and I went to a customer’s house for a site visit. The customer bought his house “as is” during the 2020 house rush. The previous homeowner had some handyman or Harry Homeowner stuff going on. House was built sometime between 50s-60s.
My master told the customer about his meter base. It’s inside of this “mud room” / “breezeway” / whatever you call it. The SE cable attaches above and wraps around the front of the structure and down, passing through the structure’s wall and into the room where the meter base is located.
My master said it’s a code violation because you can’t pass SE into a structure like this without an accessible disconnect outside. We quoted the customer on moving the meter to the side of the structure with a disconnect and running SER across the room into the utility room inside. (On top of this problem, he’s got a 200A service that is fed into a 100A panel. It’s obvious someone changed the panel not too long ago)
There’s some debate on wether this structure (I’ll call it a “Breezeway” from here on out. Please correct me if you know the proper name) was original with the house or not. My master doesn’t believe that it is. There’s no record of inspections on the breezeway (or their new panel) so it’s hard to say for certain.
The customer called the power company and they said it could be grandfathered in and he doesn’t need to change the location of the meter. We believe he didn’t properly explain the situation to the power company because it seems unlikely they would vouch for such a set up. It seems that the power company may be under the impression it was original with the house.
I’m not sure if I have a specific question here. I’d like to learn more about who is correct here. My master generally seems like he knows his stuff, so I’m inclined to listen to him. Although, I’m not sure where to look in code for specifics and I know some of this comes down to local jurisdictions and power company discretion.
The homeowner is happy to not have to do the work and pay extra money, so it doesn’t seem like we will be doing the job. That ship has pretty well sailed. I’d just like to know people’s opinions on the matter. Thanks.
