Davisteam
- Granite City, IL
Many of the Lift stations I maintain only have LFMC going from the control cabinet to the well, just like the one in the picture. I have several concerns:
Do I need to install RMC coming from the ground with explosion-proof fittings to keep gases out of the cabinet? As is, duct-seal is stuffed into the incoming openings of the connectors. The reason they were installed this way is to avoid chipping out Chico every time a pump or float would have to be taken out and repaired and/or replaced. The floats are changed more often than the pumps are taken out but the pumps are removed completely at times in order to take back to the shop for maintenance.
I’m just at a loss of what to do to make these systems safe, legal, and convenient to maintain. I should also add, that the gases do deteriorate components over time, so the duct-seal is not a good substitute. I just want to do things correctly but I’m not sure how to go about it.
