AC\DC
- Lucky to know
- EC
He called me on two jobs.
One was UF on side of home feeding disconnect to mini split.
Ran wire under lip of old lap siding. He says subject to physical damage i then say well if it is then I guess I can’t run liquid right or schedule 40 pvc.
He says that’s alright he just does not want UF.
I say they all say not installed if subject to physical damage so how can you pick and chose.
Same thing but this time exposed nmb running tight along beam running vertical.
Says it subject I’ll give him that and protect it.
The one that gets me on this is.
It’s an old garage. With existing circuits.
I ran new convenience outlets on each side of garage that are supplement to existing circuits on each bay of garage.
They are 15 amp circuits.
He telling me they have to be 20
I tell him he has existing 20 on each bay.
He says you can’t have 15amps in a garage I tell him I can.
He says if it was your house would you want that.
I say it’s about price and it’s just a convenience receptical for trickle charger if he needs more power you the existing.
He then says I can take to electrical board.
I tell him I don’t want conflict.
I try and throw a couple ideas out. He says if it’s pushed farther he bet he can find that the existing circuits were never permitted and then I’ll have to deal with that.
He tells me in his 10 years he never seen a 15 amp. And I tell him so what it’s code and that’s that.
I then tell him you can run a single 20 amp and feed all receptacle in Garage and that install Is worse the. 2 additional 15 dedicated circuits.
Am I wrong.
It’s going to cost me about 500 bucks to fix it.
Should I fight if I am right.
Am I wrong.
