- Windsor, CO NEC: 2017
- Hospital Master Electrician
I am working in a big building. That's about all I can call it. It's big. Not real big, but big. I've learned how to use (and worship) a scissor lift there.
Anyway, in this building are four large windows, about 12' high and 12' wide. We are installing some sort of recessed downlight at the top of each of the windows, to shine onto product displays that will be visible from the U.S. Highway.
There are no receptacles called out specifically for these windows on the prints. However, as I recently learned...
So, I was wondering if most inspectors would allow a lighting outlet instead of the required receptacle outlet over the windows?
(My other question was going to be where this receptacle is normally put and what exactly is normally plugged into it, but I guess half that question was answered in re-reading the section.)
Would this be something that should be caught in the bidding process, or do most commercial EC's charge for the addition?
210.62 Show Windows. At least one receptacle outlet shall be installed directly above a show window for each 3.7 linear m (12 linear ft) or major fraction thereof of show window area measured horizontally at its maximum width.
