I'm considering getting either an Ideal circuit analyzer or Amprobe INSP-3 which would at least give me the option to check at class A and B levels. Any recommendations anyone?
Peter, In addition to the INSP-3 and Ideal SureTest, I also have the Extech CT-70 and have compared all three testers both on my test bench and in the field. I still have my "antique" Woodhead Ground Loop Impedance Tester (GLIT for short) with a big analog meter, which still works great but offers much less intel than a modern load tester. Guess that makes me an antique as well...
I would leave the Extech CT-70 out of the running since it has too many screens to go through for info, and the information is too spread out for a quick evaluation. Also, there's no primary screen indication of a Bootleg Ground, which is important when testing a lot of rental property outlets.
That leaves the Amprobe INSP-3 and the Ideal SureTest. Both units seem to have similar accuracy since we've tried them out on the same outlets and they read close to the same numbers. However, I did not confirm their accuracy with an independent measurement, which is what I would do using a calibrated meter and known resistance load. But I've gotta believe their accuracy is close enough for field work. (I used to build nuclear missile guidance systems in a previous life, so calibration procedures were drilled into me...)
Both the SureTest and INSP-3 provide similar info, but the SureTest is a little quicker to use since it gives you a pass/fail indicator on the first screen that's pretty clear. The INSP-3 gives you more data on the first page, but you have to really work to interpret what it all means. For instance, while either tester finds a bootleg ground, the INSP-3 just blinks the actual impedance reading number, while the SureTest actually has 3 lights on screen that show up like a cube tester, and the ground "light" blinks a big F for false ground if it determines there's too low of a impedance between the Neutral and Ground (less than 15 feet of wire). So a wiring fault that could be overlooked on the INSP-3's smaller display is really obvious on the SureTest display. Also, the fluorescent display of the SureTest is easier to see than the INPS-3, especially at a distance, so that could be helpful to somebody with less than perfect vision (like me).
Both the Amprobe INSP-3 and Ideal SureTest have a nice carrying case with a short "euro" power plug, and both seem equally rugged. I would make the SureTest my first choice, then the INSP-3 as a second choice, and finally the CT-70. All of them will get you there, but the SureTest is the easiest one to drive.
Finally, remember that none of these GLIT's can tell the difference between a CPBG (Correct Polarity Bootleg Ground) and an RPBG (Reverse Polarity Bootleg Ground) outlet. To know the difference you'll either need to use a DMM or Wiggy from the outlet ground contact to a known earth connection such as a copper water pipe, a long extension cord ground that's plugged into a known-good outlet, a test wire run back to the service panel bonding point, or easiest of all a NCVT such as a Fluke VoltAlert or Amprobe VoltProbe. I really think using an NCVT as a quick check to discover any "hot" grounds followed up with an intelligent load tester such as an Ideal SureTest would be a very solid outlet check and quick to perform.
