- Massachusetts
Unless the OP confirms the transformer type everything is supposition.
No it is not supposition Tony, it is what we use here.
So the OP is looking for a new transformer based on something you haven’t seen?
Believe it or not, the rest of the world use transformers, they just hum a different tune.
I believe it.
But the differences in the equipment used is why I would not go to an English forum and tell them how to wire it based on my American experiances.![]()
Since I left engineering college many years ago I can’t think of anything major that has changed transformer construction.
As for differing countries, as senior moderator of a UK site I would welcome you to join in discussions.
You have codes, we have regulations, neither have an effect on the basic laws of physics. That is unless you know different.
You should try 60Hz power.More power for the same amount if iron :thumbsup:
Rearranging the primary windings will work but it involves swapping the start and finish of a primary winding.
I agree with Jim......Rearranging the primary windings will work but it involves swapping the start and finish of a primary winding. ....
That will require the OP to field modify the welded aluminum winding connections of his transformer, thereby voiding its warranty and making it likely to be rejected by the AHJ.
You’re not dragging me in to that argument……..
It would be easier to convert the UK power grid to 60Hz then it would be to convert the US power grid to 50Hz.
What do we do with all the other areas? Europe, Africa, India, China, Russia, etc. You’re the odd bods as far as frequency is concerned.
Japan really is the odd man out with both 50Hz and 60Hz
You’ll need to catch up with our technology first though.
We’ll just slow you down, it’s easier.
