Originally posted by bob:
[QB] rattus
I don't know where you are getting your information but you need to some other source. What you are putting out is just plain WRONG.
You have already admitted that you are confused by the terminology of Iline, Vline, Iphase and Iline. This is basic stuff.
Reply: Bob, we must be from different planets. I told Ed that it was confusing to use the same names for different variables. I know the difference.
The reason the apparent powers in VA are not equal is that the secondaries see a total of 240V, but the load sees only 208V.
This is not correct. The voltage at the tranmsformer is 208 and not 240. You can not add the voltages at each coil and come out with 240. Its a vector addition.
Reply: The voltage across each xfrmr secondary is 120V. Apparent power delivered by each secondary is 2 x 120 x I. But the line to line voltage is 208 so the apparent power in the load is 208 x I.
True, Papp = Preal = 208 x I in the load, but not in the xfrmr.
This is just wrong.
It is absurd to say that the power delivered at the load is not the same as at the transformer.
Reply: The real power is the same; the apparent power is not.
What is not obvious at first glance is that the PF in the secondaries is 87% because there are phase differences between voltage and current because the line to line voltage determines the phase angle of the current.
This is also wrong. The power factor of the load is 1. Its not different at the transformer. Its just wrong to put out this kind of information.
Reply: There are three voltages and three phase angles and a single current. The current cannot be in phase with all three voltages. It is in phase with the 208V because the load is resistive.
There have been several posts that have tried to correct your mistakes but you have not seen fit to
take the hint. Suggest you get some one who is knowledgeable in that area of electrical power and see if they can help you.
Reply: There have been such claims, but I insist I know what I am talking about. Somehow I muddled through engine school with passing grades. I couldn't be that dumb.
