fred-d-c
- Tennessee USA
- Maintenance Tech
I have a question. Why does the following happen? When you take a scope meter; Fluke 190-204, Putting the Channel 1 test lead on L1 and the ground clip on Neutral you will see the typical -170... +170 volt sine wave at the same time use Channel 2 put the ground clip on L1 and the Channel 2 test probe on Neutral you will see the same sine wave but 180˚ out of phase from Channel 1 measurement.
