Single Phase
After reading through all of the answers I wonder...
Why is a degree called a degree? :angel:
From the Latin de-gradus, based on dividing anythingvup into steps or stages (gradus).
Why is it the size it is (1/360 of a circle)?
Speculation ranges from the fact that one day in the earth's orbit is close to one degree of arc to the Babylonians dividing the natural sixty degree angle of an equilateral triangle up into 60 parts because of their base 60 numbering system.
:angel:
Phase angles are the relationship between the primary and secondary windings. For the usual Dyn11 the secondary red phase is 30o in advance of the primary red. IE 11 o clock.
Depending on the orientation of the windings and format 12 standard outputs are available.
This would equate to Dyn1
I?ve written a quite long thread for another forum which I have promised from my first day on here I wouldn?t mention. It will take time but I will post it here.
Thanks! :)
So, correct me if I am wrong, but in theory I could do this:
11kv buss with 2 feeders:
For feeder 1.
Yd11 11 to 3.3kv trafo
Dyn01 3.3kv to 433 volt trafo
For feeder 2.
Yyn0 11kv to 400 volt trafo
Both 400 volt secondaries can be paralleled because the vector groups in the end match zero degree of phase shift.
Thanks! :)
For feeder 1.
For feeder 2.
There is the minor problem of matching impedances.
Had the system been designed and not evolved over XX years things would have been different.
Bits were added as needed at the time. Some sections removed and reused elsewhere, which is what I think happened in this case. The older records weren?t very good to say the least.
As I said I inherited this mess when I changed companies. Trying to get money out of the accountants for something they couldn?t see was nigh on impossible. We just had to live with it.
48 phase:
96 secondary windings
16 control windings
12 primary windings
1 interphase winding
They were used in the electroplating industry when mercury arc rectifiers ruled the roost for DC power.
Now I'm retired, two things fascinate me mercury arc rectifiers and rotary converters. As I youngster I worked on both, no one took the time to explain them. I think mainly because they didn?t understand them.
