Jimmy7
- Boston, MA
- Electrician
Do you typically install single receptacle or a duplex receptacle in the cabinet above the range for the microwave?
Can be one a single 20 amp circuit if the two units together do not exceed 20 amps.What about the dishwasher and disposal? What do you typically install?
Two singles or one duplex. The duplex would require simultaneous disconnect of the two circuits on a single yoke.If it’s two circuits would you use single receptacles or duplex receptacles?
We always run 2 circuits with a duplex on each. This allows more room for bulky or right angle cord caps than a single shared duplex.If it’s two circuits would you use single receptacles or duplex receptacles?
