Sleeves
romex jockey
1st, thx for all replies, good insight....:thumbsup: 2nd, returned to the job today (monday) to find weekend warrior diggers found/installed my pipe.....:roll:
So...one end is made into garage panel via 2" w/LB & frosty.... other end is under what will be a wrap around deck....so here's what i did>>>
that's 10-3 UF in 2" sch 40
WWYD???
~RJ~
LarryFine
Can you withdraw the wire from the wall? If so, cut off the MA, put on an LB, and reinstall the MA in the LB into the wall.
Of course, you'd have to make the hole in the wall bigger. Hey, you asked. ;)
Who shot the mis-fired torpedo imnto the wall?
romex jockey
I could , but w/out a frosty it'd not last long....:happysad:
ah, that's a gas furnace vent....going to be a wee bit of a distraction on a deck .....:happyno:
~RJ~
growler
I hate to ask but why would conduit be needed at all. That's UF cable. Come up the outside of the footer and into the Garage through the bottom of that seal. Kind of where it is now except with entrance from the bottom. Cable won't be exposed to physical damage. Nail guard where you drill the seal.
