SolarPro
- Austin, TX
The CEC updates its list of eligible equipment once every month.
Couple other goodies in this inverter:
1. I recall it being transformerless ( i think it safer, as you can float array)
2. and dual MPPT.
For sure. It's really more of an intermittent convenience receptacle than an emergency power supply. But it's a significant product differentiator.
I thought the outlet was mounted on the bottom of the inverter.A question which I raised, with an "I guess we need to look into that..." response from the instructor, was whether the convenience outlet would require labeling that identifies it as powered by an alternate source and therefore potentially live when POCO was disconnected.
The outlet can be placed either indoors or outdoors (with appropriate enclosure.)
Nope. There are terminals inside the inverter for attachment of an external outlet (three wire) and external control switch (two wire?). It is not clear whether the control switch is low voltage, etc. but it needs to be wired as full line voltage since it will be in the same raceway.I thought the outlet was mounted on the bottom of the inverter.
Putting a UPS in series might be a better application of this feature. I'm not sure how "secure" a power supply is if it requires that the sun is shining. Which it isn't at least half the time. We've had miserable weather here of late and that included days on end when I couldn't have made more than 4 or 5 amps AC (120 volt) off 5kW DC.
If you want a reliable 15 amp convenience outlet, there's still no substitute for batteries.
Or a 1,000 megawatt coal-fired power station.
Talk about not getting it. This feature is precisely for the situation where the coal-fired power station is not available.
Not that I don't think solar has its place, but to paraphrase Harry Callahan, "A power source has got to know its limitations."
Tallgirl specifically said "a reliable 15 amp convenience outlet" (emphasis mine).
In no way can solar be considered reliable on a local scale (one house) and almost certainly not on a regional scale.
We will be providing labels for the inverter and the outlet that give instructions on how to activate the power and how to deactivate it when the grid comes back. Perhaps another sticker would be prudent that identifies the outlet as a possible energized source during grid outtages, similar to a battery backup marking requirement.
Greg Smith
SMA America
Senior Technical Trainer
