I agree with Dennis. Semper Fi.BuddyDennis Alwon said:I agree but you may need a smoke in the garage as well as in the bedroom.
cowboyjwc said:Since it is illegel for a bedroom to exit into a garage, my guess it that you have an unapproved strcture anyways. I would definitly check with the local AHJ.
cowboyjwc said:Says right in the original post that has a detached garage with a bedroom. Now you could be right and the room could exit only to the exterior, but my guess is that he has something that "our" planning department would probably not approve.
My other thought, that has nothing to do with the post; Is there a bathroom?
My feelers would start to tingle if I got close to this project. You have heating requirements, light and ventilation, seperation between a group R and a group U. Is it really a detached garage with a bedroom or is it a guest house, that may not be allowed, with a garage?
To answer the original question, I would say no, they do not need to be interconnected. I would treat it as an efficency dwelling unit (UBC 310.9.1.6).
I answered the question, because as someone said in another post, "Just because that's the way you do it...."
Tony Ottenlips said:There is no door between the garage and the bedroom. But they are both under the same roof.
stickboy1375 said:Why? Do you do this in a house? I see bedrooms above detatched garages all the time, they exit at grade...
Dennis Alwon said:No, I don't put SD in a garage but if it is a detached building that meets the requirements of needing SD then one must be on every level. If the garage were under the room requiring SD then I would think the garage would need a SD also. I am not sure what exit at grade has to do with SD issue.
Tony Ottenlips said:I'm going to ask the inspector, But If you have a detached garage with a bedroom(which needs a smoke) Does it need to be interconnected with the smokes in the main house??
