YES, but the question remains for the case of the inverter that needs a neutral connection but can use the EGC as a substitute: Why is there even an option? Why not just say "no neutral connection required" ? Saying the installer can put a jumper between N-G freaks everyone out because they don't want to "use the EGC as a neutral" so they end up running the neutral conductor. I have done dozens of megawatts of utility scale string inverter based ground mounts, and they all had a full size neutral run to the combiner panel boards and to the inverters, a complete waste, thousands and thousands of dollars. As I said, I have been out of the utility scale stuff for 4-5 years, maybe it's changing.
