bradeyboy
- Portland, OR
- Engineering Technician
I have a Solaredge Energy hub with a LG RESU 10H backup battery connected to a Backup Interface. The BUI has a generator connection, and has the latest firmware. What I still am unclear on is how this generator connection interacts with the generator connection. If I connect my whole house Generac to this connection, when does the contact closure turn send to the generator? The drawings I see show the Inverters and Generator connection is not isolated from each other. When the battery backup turns off, does the BUI close the contacts to provide a start to your generator? Then when the generator starts, how is it interacting with the Inverter? If at night, I don't see a problem. If during the day, it would appear that inverter solar output might feedback into the generator. Also, if the inverter is receiving power from the generator, would this provide charge to the battery? There is literally no documentation on the proper usage of this generator connection other than a footnote that it is available with the proper software. Has anyone used this setup and can provide some advice? I really don't need to burn up my inverter or my generator if they are not isolating.
