Wow - are sure this isn't some ancient boiler-plate item? I would fire off an RFI about it, he may just be seeing if you know how to read. If not I would boost up the price quite a bit, and tell him so. "It can be done - but it's gonna cost ya...." Also I think hardworking stiff had some great advice... Maybe you want to loose this bid, he might have some other wacko trash to pull. Like zero tolorance placements, and he'll be there with a micrometer to check - or some other anal garbage. But then again - he just might be some hack who has no clue on current standards - it might be his first job, or left over from it.... (IN THE 30'S!)
If you do take it, I would suggest that you add a significant amount. This jerk wants soldered splices - make him pay for it! (15+ minutes an opening, ladder time, back and forth, double handling, Catered lunch
etc. Or, T&M.) Play his game! If he wants it, there will have to be stipulations and specific conditions - IN CONTRACT! And invest on long sleeved shirts for all of your guys, and some 1200 watt irons for each and charge that to the job as well. Wire as normal - with twisted splices and a loose wire nut - nothing rolled in -
test every thing! Demand that no finish be installed before the soldering begins and is finished, with a notice of non-responcability if any finished material is on the job until after soldering is complete, and that no rock can comence until it does. Then send the cheap guys around to pull the wire nuts and solder the splices and roll in, and close boxes and rings. Have it in contract that any changes after that will require replacement of the entire cable length of any resoldered splice, which may require the entire circuit length, and and all branches of same. (Of course total non-responability of any removal of any material to do so, or replacement of same.)
He's invited you to dance.... Let's see if he can TANGO!
You just have to no how to play his game IMO.
