- Massachusetts
mdshunk said:I want a refund.
Just send me your bank acount number, I will send it right out.
iwire said:You will have to explain to me how the line gets shorter when the conductors are twisted.
don_resqcapt19 said:rattus,
Actually the resistance goes up a bit. The solder completly covers the copper and has a higher resistance than does a solid copper to copper contact.
Don
georgestolz said:Can I see a show of hands of who here has soldered wires before?
I, for one, have not.
That is correct... neglected to put that in there. But it should be noted that while there will be contact "area", that area will be comparatively small to the conductor's surface area. I wonder how much relative length would have to be twisted to achieve a contact area equal to each conductor's cross-sectional area...?rattus said:Smart, the copper compresses somewhat when twisted, and this provides the contact area.
Agreed. Yet wouldn't the significance be in direct proportion to the current passing through the connection? Measurements are usually taken at quite low current levels and therefore would belittle the significance.rattus said:It is logical that solder would increase the contact area and therefore reduce the resistance, but the change would be small.
When you twist two wires, the path of contact is a straight line through the center of the twist (mind you, in a perfect scenario). Twisted wires are shorter in length than their straight version counterparts. Hence, the line is shorter.rattus said:The length of the "twist" would be shortened as the twist is made tighter, but the length of the contact area would not change, however the width would be increased and hence the contact area would increase.
Smart $ said:When you twist two wires, the path of contact is a straight line through the center of the twist (mind you, in a perfect scenario). Twisted wires are shorter in length than their straight version counterparts. Hence, the line is shorter.
Smart $ said:Twisting does not increase the contact "area" for the same length of wire. In fact it reduces the "line" length.
mdshunk said:No, we actually had a conversation about it. He is able to present this to the potential buyers as one feature that makes his homes superior to others. Whether this is actually true or not is another story. Perception is reality; sell the sizzle not the steak; etc., etc.
I'm actually anxious to do a solder job just to say I did one (or several). Kinda like paying homage to the electricians of yesteryear. Reminds me of a saying a plumber once told me:
A hundred years from now, they will gaze upon my work and marvel at my skills but never know my name. And that will be good enough for me. -Dan Holohan.
The contact area will be the same length as the twisted conductors. Through deformation of the copper the contact area approximates a helical surface, therefore having width. The length along the outer edge of that surface would be longer than at its center, the axis. However, the axial length is the dimensional length. Note width is exaggerated in the following image.iwire said:The line itself, the contact area, will not be shorter, which is what you seem to be saying here..
Smart $ said:The contact area will be the same length as the twisted conductors. Through deformation of the copper the contact area approximates a helical surface, therefore having width. The length along the outer edge of that surface would be longer than at its center, the axis. However, the axial length is the dimensional length. Note width is exaggerated in the following image.
For clarity, "area" in the second quote of your post is the line.iwire said:That is all very nice, but is not what you had said.
Twisting does not reduce the length of the line.
Smart $ said:Twisting does not increase the contact "area" for the same length of wire. In fact it reduces the "line" length. Twisting does however provide additional mechanical strength to the joint.
Smart $ said:As I said before, the contact line is the center of the twist, i.e. axial line. The centerlines of the wires form a two-strand helix about the axial line. The following example makes a relative comparison of those lengths.
I have both "Soldered in building wiring" and "Soldered in electrical applications other than building wiring".georgestolz said:No comment:
Smart $,
iwire said:A lot of flash and still no direct answer.
You chose to be 'picky' in this thread so I am just being picky with you.
You clearly indicated in post #31 that "the line" would get shorter. Well the 'line' does not get shorter; it is simply in another shape.
So what was it you where trying to say in post 31?
You don't have to open your graphics program for this question.
Afraid not.rattus said:The length of the contact is the length of the wire in the helix, not the axial length of the helix.
