sparkydon said:
tried a search to no avail..How much difference in quality is solid cented copper RG6 compared to the copper clad 60% AL RG6? In what applications is the difference insignificant or at least not noticeable?
For RF use, the copper-clad center conductor and aluminum braid/foil shield is more than adequate. There is practically zero benefit to a solid-copper conductor (and/or copper shielding), due to skin effect at RF frequencies.
On the other hand, for audio and video signals, I'll take an all-copper RG-59 over any RG-6 every time. It's more flexible, solderable (although most use compressions or crimps), and easier to fit terminations onto. Plus, the impedance is more suited to A/V use.
The real difference in cable types, other than impedance, is the signal loss over distance, usually stated as X db/1000ft @ a given frequency. In either case, careful and proper termination is more important to signal transfer quality.
