Can solid wire (say #6 solid) be butt spliced using a crimped connection? I have never seen a solid wire crimped.
Thank you.
Just curious, who uses #6 solid and why?
Cadweld or similar should be adequate but may be more expensive than the new 6.It is for GEC extension.
The plumbers did a plumbing upgrade and the city has required a new grounding system. The plumbers did not do the GEC properly so the customer wants me to use a butt splice to extend the GEC to the panel and I refused to use a crimp and butt splice on the solid wire.
I said I will replace the whole system properly without a butt splice.
Irreversible crimp is all you need.It is for GEC extension.
Burndy YC4C6 less than $6 if you have the tool or can borrow one.Irreversible crimp is all you need.
Don't call me stupid, but I've wondered about using a swaging tool and aluminum crimp sleeves. The kind you would use for wire rope or Airline cable.
Never done it, but I thought about it in the past
Funny you mention that. Last spring, I had to extend a Ufer connection to feed a new panel location. #4 wire fits a 3/16" oval copper Nicopress sleeve. Perfectly. Not a listed splice, but DEFINITELY irreversible and low resistance.
I did this at my parents' house; I sleep just fine knowing how I did this splice.
SceneryDriver
I know about the irreversable crimp option offered by NEC. But are the splices listed for SOLID conductor?
care to explainI did this at my parents' house; I sleep just fine knowing how I did this splice.
SceneryDriver
Copper is malleable so I guess it can be crimped. Even at #6AWG or around 16mm2 would be closest for us in the SI world........Can solid wire (say #6 solid) be butt spliced using a crimped connection? I have never seen a solid wire crimped.
Thank you.
Good Eye Fionacare to explain
