Electromatic
- Virginia
- Master Electrician
Hello, all. I've worked around VFDs on several occasions and have read much about them but haven't really done installations. I have a customer that wants them on several pump motors. The existing arrangement is a MCC in the room then non-fused disconnects a few feet from the motors then, of course, the motors. The basic plan was simply to come out of the disconnect to the VFD then from the VFD to the motor.
My first question is, should I bypass the MCC controls once the drive is installed? I'll have to take another look, but I don't think there is any inter-connectivity or PLC type operation involved in the MCC.
Secondly, I just found out that they want to install line reactors as pictured. Where/how do I mount these? They won't fit in the disconnects. Can I mount them in the MCC? A separate enclosure near the drive? If a separate enclosure, would it need to be vented?
We're not doing any of the drive control wiring or programming. I thought it would be a pretty straightforward moving-around of some line-voltage connections, but now I'm not so sure. It will be good experience with drives, though.
Thanks as always for any help!
