Alwayslearningelec
- NJ
- Estimator
How about surface mounted box with MC cable behind wall?I’ve used wiremold boxes for that before, but a shallow UT box will also work, but it is tight on wire fill.
You would have to use a 90, but you could.may be an issue the MC being close to the Sheetrock making it subject to damage.How about surface mounted box with MC cable behind wall?
The MC cable will fit in the 7/8 void so that would work. The cable just needs to be 1.25" from the hat channel.How about surface mounted box with MC cable behind wall?
I would say no. Box would be flush with the drywall.Is it possible to get a box behind the gyp board? Seems like there would only be about an inch space behind gyp board so I'd say no.
Isn't that box 1" deep? How will that fit in a 7/8" space?Just there recently with a pipe in the way. If you have 1-1/2", use the Raco 418 and a 1/2" single gang mud ring. 14.8 cu in plus 3.5 for the mud ring. That will get you #12 NM in and out, a device and use of the box clamps. It will be tight and use every cu in.
Yup and then they'll ask you for a solution. If the boxes had to be flush with the finished wall they could have put them in the concrete.Sometimes you just have to tell the customer "NO".
I don't believe that those are flush when the drywall is installed. The covers are raised. Can they be used with MC cable?Arlington electrical is making a box for furred out wall. Listed
