mikee0101
- South Carolina
- Maintenance
Looked up codes but still confused whether this allowed or not .Saw the 40% rule . But have always put sub panels on its on breaker .This is on a residential house built in the 60's ?
What is your question?
Do you have a separate panel fed without a breaker from a splice on the service conductors? Is this separate panel located next to the main panel? Is this separate panel supplied with separate ground and neutral?
Can you post a photo?
-Jonathan
Right-click on image, select Copy Image, click in forum window, right-click, select Paste.Trying to post picture but can't find a way to pull from gallery.
