iwire said:Mini system or not the NEC requires some sort of disconnecting means at the indoor unit.
jerm said:WooHoo! Post 500! I'll catch up with Bob someday!! (at this rate, long after we're both dead though)
peter d said:I agree, however, I have yet to see one installed on a split system.
Which is sort of a pain to do, sometimes. Something that could be done at the factory for a couple bucks costs a couple hundred, sometimes, to pull off in the field. I havn't looked into it thoroughly, but I suspect a breaker lockoff might be the thing to do.iwire said:Mini system or not the NEC requires some sort of disconnecting means at the indoor unit.
iwire said:S&S computer rooms.
BTW sometime they are just a regular SP switch in a wall box.
Then you must not have seen any of my work?peter d said:OK, strike that, I have seen them.
In residential I never have though.
stickboy1375 said:I swear the last split unit I did the indoor blower was low voltage...?
jerm said:mitsu makes a minisplit that has 12v fans indoors. They're really quiet. The included IR remote is nice too.
stickboy1375 said:I think that was it, they were DC voltage right?
iwire said:Still needs a disconnect. :smile:
stickboy1375 said:Next time... :grin: I promise
Maybe, but some have seperate feeds for each part.Chamuit said:The point is a disco by the inside unit may cause a unit to not operate properly.
