billdozier
- gulf coast
alfie thanks man gives me something to propose to my boss for some reason I thought we couldnt run a 12/3 mwbc for disposal dw does anyone see a problem with this?
Do you pigtail every outlet to a single connection point for trim out?
Ok, I admit it, I was trying to see how many pigtail then land onto the duplex......and its sounding like nobody....
Our town, for what ever reason only runs 20 amp circuits, so landing 4 #12's on a duplex is hard to stuff IMO....I've always pigtail'd
I believe Alfies point was that steelerman was incorrect in saying that a half switched outlet is not code compliant without an additional outlet.
......If I pigtail 12's I pigtail down to 14gauge to make it even easier for trim out. .....
I hope you're on a 15a breaker....
Thanks for the info on the d/d we always in resi wrap both screws use the device except for switches I pigtail number of hots per switch wish everyone would I hate one long hot wire to 3 switches total pita imo
If there was some capitalization and punctuation in there, I might understand it.:wink:
I never could get into the text thing I mean I got the phone in my hand why not just dial the number and talk.I totally understood it do you ever text message??
If I get to do the designing, yes, I do it for most rooms; in particular, living rooms, dens, and bedrooms.How many of you actually split duplex recepts any more on a regular basis?
i believe in the 08 code that you are no longer allowed to split the recept and have the bottom one (always hot) count as your required recept for wall space. If using a switched outlet instead of a light, it doesn't cont for the required outlets.
Yes, I do pigtail the black and red because there's only one screw available due to split-wiring, unless the receptacle has two back-wire holes per screw.Ok, I admit it, I was trying to see how many pigtail then land onto the duplex......and its sounding like nobody....
I prefer 20a for most receptacle circuits anyway, but two 12/3's and a duplex call for extra-deep boxes anyway.Our town, for what ever reason only runs 20 amp circuits, so landing 4 #12's on a duplex is hard to stuff IMO....I've always pigtail'd
Why not leave the neutral side intact and use a 14/3?When I have ran the two 14/2's to the DnD box I have made sure that both the hot and neutral side tabs are broken and that the circuits originate from a two pole tied breaker.
I hope you're using 15a breakers when you do that.If I pigtail 12's I pigtail down to 14gauge to make it even easier for trim out.
I do the pigtails for the hots, but the single wire for the EGC's.we always in resi wrap both screws use the device except for switches I pigtail number of hots per switch wish everyone would I hate one long hot wire to 3 switches total pita imo
