i don think the conductors are marked thwn.thhn...ect
are they?
And the equipment ground is not insulated. In the nm
exactly
And without the sheath, the conductors are unidentified.egc not insulated,NM cable in pvc even if conductors are listed for the installation is a violation,because the outer sheath is not.
If it's 6/3 w ground and its coming right out of the crawl/basement then I see nothing wrong but if it is a separate building, then it needs a insulated EGC. ....
175 feet back to main panel, crawl space, basement ? If you mention this I'm sorry I didn't see it. Is that 6/3 with ground? Is it coming out of the crawl/basement right under the panel on the house or is this a separate building? If it's 6/3 w ground and its coming right out of the crawl/basement then I see nothing wrong but if it is a separate building, then it needs a insulated EGC. If it is coming out of the basement/crawl then NM would be Ok until it got outside but for that short distance I would not change wiring methods.
See post 35I wouldn't bother changing wiring methods either in that case of such a short distance - sort of splitting hairs idn't it?
just so we're clear on what this is:
6-3NM w/ ground
175' to main; 100' underground in 1" conduit
feeding a pool panel
6-3NM w/ ground
