Spot the violation
forgetting the "occupancy or group of occupancies" controversy, is that PVC being used as the riser? Is that legal? I've never seen it used for that, that's for sure.
I don't know what you mean by "same hole". Looks like two weatherheads.
edit: oh, the hole underneath? weird. That ground looks small too.
PVC is probably the most common riser material around here, followed by RMC for mast services.
We never, ever use EMT for risers here because it does not last very long.
bth0mas20 said:
Is the service energized....It looks like their are two meters missing with exposed voltage.
Could either be disconnected at the pole, or have a couple of those clear lexan covers over the sockets.
2" PVC, if thats what it is, requires support every 5 ft.
Service conductors must be 3 ft above a window that opens.
