dab
- Gasquet, CA
not exactly your answer, but when i install a receptacle i have opted for spec grade. the ease of installation along with a higher quality product.
Was there ever a time when a suitable sta-con was not available?peter said:Mr. Celtic,
When I do motors, I use crimp terminals -- preferably the hook or round hole ones.
~Peter
celtic said:Was there ever a time when a suitable sta-con was not available?
I have. First, make sure it is a tight twist, and second, it gets wrapped clockwise.peter said:I haven't seen much difference whether the wire is twisted to the right or the left.
I just start a strip at 1 1/4" and leave it not fully stripped. After it is wrapped and the binding screw is tightened, I tape the run and end insulations together. This helps keep the end insulation from sliding off the rest of the way and creating a potential hazard.The usual method is to leave a bit of insulation on the tip of the wire. This helps hold those unruly strands together. [The usual method is to strip ~3/4" and then, using the strippers, cut the insulation about 1/2" further on and carefully move that second piece to the end of the wire.]
