LarryFine
- Henrico County, VA
- Electrical Contractor
Correct. Basically, you have to replace SE with SER. You're also supposed to replace 3-wire major appliance conductors, receptacles, and cords, and separate the appliances' bond connections.MEP Guy said:Thanks guys. Just to be clear ... the ATS will be the new main - the ATS EGC will have bonded nuetrals and grounds and will be run back to the current service entrance grounding electrode system.
Ground and nuetral at the existing equipment (no longer the service entrance) will need to be seperated ... correct ?
I once had to delve deep into an older dryer to find where in the wiring harness the white and green condcutors were joined. I cut the jumper and capped the neutral side of the cut.
