Affects real-time game play much more than video....while its not much it can be a problem in video and game play.
That's why I said its not a good indication of forum speed unless the test is to the forum server.The forums performance has more to do with server load and resources than bandwidth. Those speed tests show if your internet connection is performing as it should so you can be sure any slowness on the forums is not caused by your internet connection.
It would still be a better indication of forum speed/performance than testing speed to another server. That said, you could make a hosted speed test available to only a select few... perhaps the forum administrators.Hosting a speed test would increase the load on the server, consume costly bandwidth and still not be a good indicator of performance.
It is noticeable on my end :happyyes:The forums are now running on the fastest and most optimized configuration they have ever been on. We've capitalized on the recent situation and made every improvement possible right down to the backups.
Wow you gots great speed compared to me. I must be living in the dark still.:happysad::?
I just checked and I could add to the bottom of your post. Is that what you meant?
When I went to edit my post and add my speedtest after the Verizon image, I could not get the cursor after the Verizon picture.
I was only able to add before the Verizon image.
Hmmm.... seems to me it is doing exactly what you are saying it is supposed to do :blink:This has happened regularly on threads that contain more than one page- When I click on the button "Go to Last Unread Post" it takes me to the last page, not the last unread post.
