Twenty some years in the business ( mostly service ) and I still can't answer all the questions. Here's the scenario. Seven wires in a pvc conduit in a concrete slab feeding two 600 volt three phase motors with a ground. 40' from the MCC in a pool filter room. A few years back I had a bad wire and replaced all three with new. I should have replaced both sets at the time but Friday afternoon at 4:00 made one set seem the right answer. Now they are both new. I had a mechanical maitenance person call to say that when he shut down the motor and pulled the fuses he still had 200 plus volts at the motor. I doubted this fact until I tested and verified this as true. After shuting down the second motor in the conduit the stray voltage went away. The megger showed the older set as having poor insulation. The newer set tested good. I pulled all conductors out and replaced them with new. I found one conductor in the older set with a pinhole in it. All the other conductors looked to be in good shape with no visible signs of deterioration. Any thoughts?
