delectric123
- South Dakota
Is their a hand tool available that would work for stripping the jacket off of scrap cable like #1 or larger?
How big are the pieces? A good heat up in an oven or barbecue grill makes stripping with a razor knife pretty easy.
btw its direct-burial cable. would it still work?How big are the pieces? A good heat up in an oven or barbecue grill makes stripping with a razor knife pretty easy.
Too bad you don't live near Fulthrotl; he bought a machine back in 2014. You should PM him to see if he can give you some pointers.
I just have random pieces of scrap that comes up at the end of a heavy wire job. Nothing near hundreds of feet.
You can say that again.A beer or two & a sharp utility knife. Wear gloves to protect your hands.
While stripping wire in my back yard an inadvertent slip of my utility knife blade into the flesh of my unprotected thumb, all the way down to the bone, changed a semi profitable afternoon into a trip to the emergency room. If I had cut a tendon instead of just flesh it would have been even worse.
That's why I was wondering if there wasn't a tool available with a guide of some sort.
the technique that works best for me is to clamp the end of the wire in the bench vise,
use a fresh blade in a STANLEY #100 FIXED BLADE KNIFE, hold the wire in the left hand,
and the knife in the right hand, and then pull backwards against the wire.
you want a fixed blade that is solidly held, not a retractable blade.
you are actually pulling the knife by pulling with your body,
so that your hands remain motionless relative to each other,
and if the blade slips, you lurch backwards, and your hands don't
move relative to each other. i've been doing it that way 40 years,
and i've not had any issues, but sometimes it freaks people out to
watch you do it.
if you do it that way, and instead pull with your arm, and not your full body,
expect a trip to the emergency room shortly. :slaphead:
