090301-1312 EST
This post goes off topic but the diversion results from going back looking at some history.
The first operational SCR and circuit was 1957. Without digging further the Triac patent application was 1961 and apparently commercial availability was 62 or 63.
From what I believe is the first edition of the SCR manual copyright 1960 I found the following SCR devices listed --- C10, C35, C36, C40, C60, and C70. Also listed are some Unijunction Transistors. The second edition is a 1961 copyright.
In 1961 I started some development work for the Charles F. Warrick, Co., on a conductive liquid level control using a small thyratron. Then in March of 1962 the GE sensitive SCR, C7, became available. C7U $8.10 each for 1 to 99. C7B (200 V rating) $19.80 each for 1 to 99. The maximum gate trigger sensitivity was 20 microamps and the typical rating was 5 microamps. This device was obsoleted by June 1962 by a new version of the C7. With the availability of this device the dessign was changed from a thyratron to an SCR. A patent application for this circuit was file August 29, 1963 and the patent was issued March 19. 1968. One of the patent office references was 3,165,688 by Gutzwiller.
Also in January of 1962 I was working on the development of a solid-state circuit breaker for Mechanical Products. In the experimental model I used back-to-back C10B SCRs for the power switch.
For some of the history on the SCR and Triac visit:
http://semiconductormuseum.com/Transistors/GE/OralHistories/Gutzwiller/Gutzwiller_Page12.htm
and read and listen to the material. These are only excerpts from his oral history. It would be interesting to hear the complete recording.
No author's name was on the first edition. Gutzwiller is listed as editor on the second edition. The first edition cost $1.00 and the second $1.50.
http://en.wikipedia.org/wiki/Thyristor
Things moved fast in those days, and today.
Probing the Internet many interesting things show up.
http://semiconductormuseum.com/HistoricTransistorTimeline_Index.htm
http://semiconductormuseum.com/Transistors/RCA/OralHistories/Herzog/Herzog_Index.htm
http://www.semiconductormuseum.com/Transistors/RCA/OralHistories/Herzog/Herzog_Page7.htm
In the RCA demo TV set of 1952 point contact germanium transistors were used. About 1953 the CK722 hobbyist junction transistor became available at about $4 each. I had thought it was 1954. Note at this time average wages may have been in the $1.25 to $1.50 per hour range.
In the summer and fall of 1952 I was stationed at the Brooklyn Naval Shipyard working on a tube project in a test group that was developing test techniques for the point contact transistor. To the best of my recollection there was no discussion at this time of the existence of a junction transistor.
On a project in 1955 on the development of an electronic ignition system we used some Delco germanium power transistors in the power supply to convert 6 V to a much higher voltage where a thyratron dumped a capacitor charge into a transformer to provide a very rapid rate of rise of the spark voltage.
History on the Delco transistors:
http://semiconductormuseum.com/Tran...t_EarlyPowerTransistorHistory_Delco_Index.htm
