See that all the time and have installed like that on my mothers house. Windows, service must be x" from windows; poco in N.Y. Tells you where they will hit the house.
That is NEC rules. Some places may have amendments, POCO requirements, other codes, or just plain ignoranceHere the rule is for the open conductors to be at least 3' from an openable window. Neither pipe nor SE cable are considered open conductors, just the single conductors in the pipe or cable.
Why are we allowing the term "subject to physical damage" to be openly interpreted?
Why is this an epic fail? In many places this is code compliant.
If it is a million dollar house, I'd expect to see underground supply. We put in a lot of underground supplies even on 250k and less homes. Just looks cleaner overall not to have anymore then necessary on the outside of the house.Oh it's code compliant, it just looks like you know what. Only critical part of this is that the point of attachment and drip loop must be at least 3 feet from from that window which threw this guy for a loop and made him go through all those contortions. He could have dropped straight down to the meter pan which can be next to the window. Next, he should have installed the panel in the unfinished basement over to the right more so the SE could drop straight down from the bottom of the meter pan and enter the sill above the basement window. Here, the unwritten rule is 5 feet inside before it hits the panel.
Everything in one line. It's called planning!
This house is listed at just shy of 1 mil. I would expect crap work like that on a 250K flipper.
Now I see that the builder planted a tree in front of that mess so it's not so noticeable from the street.hmy:
I guess my point to all this and to be on-topic is that sometimes installers take liberties with SE because it's easy to work with. If that had to be a pipe service you wouldn't see all those bends.
-Hal
but that is because I have geothermal heat pump.
Yes, I really like the thing also. Quiet and efficient.You just had to throw that in,,,, didn't you.
JAP>
That is why you need to work for the owner and not the builder as much as possibleThank you. I originally thought that's what they were going to do. It's only about 35 feet to the pole and the builder had a backhoe on the site all the time.
That's why I never do new houses. Builder always has some trunk slammer that will do the job for half what I would charge.
-Hal
1) House is spec. For sale by builder.
2) I just don't put the cable in until I'm happy with it. I would have no problem standing there with a tape measure while he digs.
-Hal
Now you are putting yourself on other side of situation I mentioned before, you need to drill the holes in the right place, just like they need to dig your ditch the right depth. They may not be happy if you drill holes for a drain pipe and don't slope it correctly and/or don't get them in straight enough line.Same here. Wired a multitude of spec houses and worked out a lot of deals with the GC's and other subs. For instance, we might agree to drill some holes for the plumber in exchange for them doing some excavation or ditches for us.
Roger
A little conversation before you start has a way of solving those problems.Now you are putting yourself on other side of situation I mentioned before, you need to drill the holes in the right place, just like they need to dig your ditch the right depth. They may not be happy if you drill holes for a drain pipe and don't slope it correctly and/or don't get them in straight enough line.![]()
Same here. POCO actually requires RMC. One guy argued that the code says he can run EMT, I told him it did and it also allows cable, the utility on the other had does not follow the same code book we do and if you want to get it approved you'll run the RMCSE cable is a chapter 3 wiring method...
Again make a code propsal. Otherwise your complaints are not heard.
And a comment. In WA we are not allowed to use SE cable, its in our state code rules (don't know why). So for us its pipe and wire. Standard is a 200 amp service as our power rates are fairly low, a 200 amp panel is $80.
Now when I go back east I see SE cable everywhere, looks odd. Eastners come out here and see pipe and wire - wow, whats with you sparkies?
