Charlie Bob
- West Tennessee
I have to move a subpanel about 15'.I'm using the old panel box as a pull box where i'm splicing old romex without ground to new romex.(rewiring is out of question)
I was gonna use gfci breakers but there are 12 circuits so that would bring bid way up, talked to inspector and told me that everything, as long as i don't mess with receptacles was grandfather-in, so i didn't need to do that i could use regular breakers.
I'm gonna feed subpanel with new 4 wire service wire, and of course i'm not using main jumper in subpanel.
-Should i hook the EG from this new romex to the ground bus bar , or i should leave it unhooked?
-Is there anything else you all would do to it?
(this subpanel is in a basement with concrete flooring, and is fed from a 200 amp panelbox in the same basement.) (the old 60 amp fuse box supplied the old part of the house)
Thank you all>
Thank you all>
