To get by the requirements of a sump pump plugging into a gfci receptacle in a basement.
Is it permissible to remove the plug and hard wire it with a switch instead ? And if so , does it void UL ratings of that pump.
Also, if the sump pump is tripping the current gfci receptacle it is plugged into.. but does not trip in a standard receptacle... does it mean that pump is defective?
Thank you..
Thank you..
