darunedefig
- HV, New York
- Electrician
Normally for remote meters I would put in an AC disconnect at meter where the neutral to ground connection would now be and re-work the main service panel to make it a subpanel(no N-G connections).
My main question is if there is a way to tap "supply side connection" at a junction box under a remote meter that is 200' away
without having to re-wire the main panel or put a new service disconnect in ?
See attached image.
Lets assume for the existing system that the neutral to ground connection is at the main service panel at house.
My issue being the neutral to ground connection. Could you tap the neutral at JB below meter and just run the PV EGC to the house?
Or is there an even better way to do this? Parallel service?
See attached image.
