T-tapping 208V or 240V
Brown Scotchlok™ IDC run and tap connector in a box for tap size 18 to 14 AWG and run size 12 to 10 AWG.
Sorry, I see you need a device for larger conductors.
Live tap connectors. No slack needed.
Burndy BIPC4/06 4/0-6 AWG Insulated Connector
Sent from my SM-N900P using Tapatalk
There is also parallel groove or "H" taps, "C" taps - which are basically considered irreversible crimped on connectors. There are also non self piercing items that are otherwise similar to the mentioned "KUP-L-TAP"
All the methods mentioned so far work for anything under 600 volts.
