kwired
Electron manager
- NE Nebraska
- EC
our department must insure the manufactures design we do not have the right to check their calculations.
It is different from state to state. Here no electrician has the right to change those calculations either
That is fine for the first sale and installation of such a home. Sometime later when you want to modify or add on, it no longer matters. Load calculations are necessary to see if existing service can handle added load, existing branch circuits may possibly be extended, removed, or new branch circuits may be installed.
Around here it is common to see manufactured homes placed over a basement. The basement is part of the entire structure when finished, but is field built and wired, but the manufactured home portion is same as it was when it left the manufacturer.
