Tandem Breaker Tie Bar
Strange, I must have a bad PDF because when I just looked in my softcover 2011 it is there. :huh:
It's funny how one small typo can make a great big difference!
I think I'm good with that switch under 2011 which Florida uses for code. Some have responded about not being able to use it for more than one circuit, but if I went with a MWBC, according to code, it's still 2 circuits feeding 2 separate receptacles, even if they are in one box, so I I'll just stay with it using the 404.8(c) exclusion. I will tie bar the tandem breaker, and even though I didn't need to add any additional grounding (emt/metal boxes) I still ran the ground wire and pig tailed the boxes, switches, and receptacles anyway for safeties sake.
Kevin
Kevin
404.8(C) is a struggle for me. This was new to the 2008 edition and continued in the 2011 edition. It was pointed out by some that the last part of the sentence after the coma was in conflict with the UL Standard. So, in the 2014 edition this last part of the sentence was deleted. That left things such that the switch had to be listed for 2 circuit or 3 circuit, period. In this context I believe that the use of a MWBC would not be allowed either, as the technical discussion seemed to be concerned about the line to line voltage. That begs a question, where would one use a 2 pole snap switch if the only ones available are not listed for 2 or 3 circuit?
As for your situation, I think it is a quandary, as 2008 and 2011 404.8(C) allows this but it would violate the listing and hence 110.3(B).
Interesting thank you
Technical issues or not article 100 defines a MWBC as a single circuit.
What is a collar box?
Collar box=extension ring. Sorry I should have avoided the local lingo. :)
I suppose you could use it in a parallel switch rather than 3-way configuration to allow independent control of two sets of loads. Or to control two sets of inductive loads where the two combined exceeded the switch rating.
Or for some wierd combinatorial logic?
... That begs a question, where would one use a 2 pole snap switch if the only ones available are not listed for 2 or 3 circuit?
Same line-to-line circuits that use a 2- or 3-pole breaker.
I'm not so sure that is the case. The discussion around this seemed to imply that the line to line voltage was the issue. That's why I indicated that a MWBC may not be allowed either.
Well you obviously cannot use a switch that is not rated for the voltage that will be imposed upon it... :D
