cookerobert21
- East Yaphank New York
I was about to perform a tap in a 200 amp main panel in the homeowner's garage I was planning on putting my disconnect back to back from the main panel outside the homeowner's garage with a 3 inch nipple My boss showed up and quickly informed me that I could not do that because they disconnect would have to be below the main panel where I'm tApping I did not see an issue with it because I am within my 10 feet pv system size is a 10K with two 5K inverters that are being Placed outside garage wall Disconnect size 60 amp fuse disconnect with 60 amp fuses If something Could guide me in the right direction to why he said this to me if it is even true I'm a little confused
