Are you basing that on the idea that a circuit with one directly wired outlet and one connection to an OCPD with downstream loads is somehow prohibited?
If that configuration is in fact allowed (and I think it is) then the wires from the source breaker (which is both a feeder and a branch breaker!) to the point where the paths to outlet and OCPD diverge are both branch wires and feeder wires.
If the configuration is allowed, then the load calculation for the circuit could be a little dicey, since the rules for branch circuits and the rules for feeders differ slightly. I guess you figure the load both ways and use the larger wire size.
