JJWalecka
 - New England
Could anyone provide me with the technical data for #10 wood screws hex head?
			What is it that you want to know?Could anyone provide me with the technical data for #10 wood screws hex head?
The question I was hoping to answer in a nut shell......
How much wieght can a #10 woodscrew hold before it fails?
OP refered to "Hex-head" so I'm guessing you are meaning a 3/16" steel Lag. If so:The question I was hoping to answer in a nut shell......
Depends on the wood, the density, thickness, and the length of the screw.
Precisely.
Also, you want to avoid the end grain as the threads of the screw will cut and slice the fibre of the wood and basically pulverize the grain resulting to very little holding power.
In addition, it is extremely important as to how you prepare the wood for the screw. In most cases you just can't simply drive the screw in as you will most likely damage the wood causing it to split or even snap the screw off.
I always hold the screw up to the light and sight the core or solid portion of the thread. Then hold a drill up to the screw matching the drill size to the solid portion of the thread. After using that drill size to drill a hole the is at least a deep as the screw is going to penetrate when you drive the screw in the screw threads will cut into the side of the hole that you drilled. One thing that you can think about is the hardness of the wood though. Should the wood be very hard you may find if difficult to drive the screw in. If so there is not issue would you use the next larger drill bit. But remember that you don't want to go overboard because making the hole smaller may not be an option.
If the wood is softer you may want to go with a smaller drill than the size of the solid portion of the thread. In doing so the screw will compress the wood as you drive it in increasing its holding power.
A little spit works wonders too... if you are only doing a few and don't have other means handyMy dad's trick for longer screws or very hard wood was to take a bar of ivory soap and coat the threads by rolling the screw across the bar. Seemed to work.
I worked in a hardware store when I was in HS and we sold small blocks of bee's wax for that purpose.My dad's trick for longer screws or very hard wood was to take a bar of ivory soap and coat the threads by rolling the screw across the bar. Seemed to work.
Good stuff - beeswax. Also used as a lube for drilling aluminum. But I've never bought a little block - always used a toilet wax ring - preferably unused. According to my dad, they were made from beeswax.I worked in a hardware store when I was in HS and we sold small blocks of bee's wax for that purpose.
Yellow 77 also works for this![]()
The toilet ring is a lot softer than the blocks we sold, but I think you are correct that is (or was) a beeswax product.Good stuff - beeswax. Also used as a lube for drilling aluminum. But I've never bought a little block - always used a toilet wax ring - preferably unused. According to my dad, they were made from beeswax.
ice
I have been told that phillips heads are designed to have the driver slip out to prevent excessive torque on the screw.... So much easier than phillips - no slipping- no having to bear down with as much weight as possible. ...
From Wikipedia:I have been told that phillips heads are designed to have the driver slip out to prevent excessive torque on the screw.
By design, Torx head screws resist cam-out better than Phillips head or slot head screws. Where Phillips heads were designed to cause the driver to cam out, to prevent overtightening, Torx heads were designed to prevent cam-out. The reason for this was the development of better torque-limiting automatic screwdrivers for use in factories. Rather than rely on the tool slipping out of the screw head when a torque level is reached, thereby risking damage to the driver tip, screw head and/or workpiece, the driver design achieves a desired torque consistently. The manufacturer claims this can increase tool bit life by ten times or more.
Torx is not a very common type of wood screw drive (yet?). Square drive is more common. Of course this is regarding flat head wood screws. The OP referred to hex head, so I don't believe there is going to be any cam-out issue.I used that trick too, until I discovered torx head screws. So much easier than phillips - no slipping- no having to bear down with as much weight as possible.
With a torx, I think you could just keep going until you ran the entire head straight through a 2x4 if you wanted to.
Of course this is regarding flat head wood screws. The OP referred to hex head, so I don't believe there is going to be any cam-out issue.![]()
