- Placerville, CA, USA
- Retired PV System Designer
But it might blow the meter at the same time.Connecting a meter across the terminals will discharge the cap. You are putting a load on it.
Sure, that's what I want is an hvac guy, at a $125 an hour standing around with a nine volt battery, some resistors, and a thousand dollars hand held scope checking out the charging profile of a twelve dollar starting cap.
HID lighting capacitors need to be within 3% or the light may not work properly. Motor capacitors I believe are typically manufactured to 10% tolerances and is one reason you can't use a motor capacitor on HID lighting.Excuse me for being lazy, but I did not read all of the replies. An A/C buddy of mine, shorts them out, then tests them. His rule of thumb is, if they read within 3% of the name plate, they should be fine. Side note, the had installed a name brand cap. and was still having problems with a unit (outside air conditioner (heat pump). The fan would run in different directions at different times. Cap. was defective.
True, but you'll need to wait a long time; the impedance of a DMM is usually more than 10⁷Ω.Connecting a meter across the terminals will discharge the cap. You are putting a load on it.
The low-Z function on many meters might not be much help, either. Were it a continuous load, the meter would be dissipating dozens of watts while measuring hundreds of volts. I suspect the circuitry applies the low-Z load briefly, measures the voltage quickly, then removes the low-Z load. (I'm speculating here and would welcome someone with either design knowledge or experimental data chiming in to confirm or deny)
